RV.Net Open Roads Forum: Fifth-Wheels: lamination on 5th wheel
 > lamination on 5th wheel
whistlebritches
Cherryvale, KS
Posted: 09/19/23 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Cedar Creek 37' RDQS 5th wheel. The lamination underneath the cap has a couple of places that are sagging slightly. We have not had any leaks inside the RV. How difficult is this to repair and how expensive.
MFL
Midwest
Posted: 09/19/23 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
A bit more info would get more replies. A pic would be best!
ScottG
Bothell Wa.
Posted: 09/19/23 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the front cap? There were some years where heat from the sun was causing delam problems in that area. Or it could be leaking from a clearance light, etc. and that wouldn't necessarily show up on the inside.
Either way it has to be peeled back and re-glued.
JIMNLIN
Oklahoma
Posted: 09/20/23 11:46am Link  |  Quote  |  Print  |  Notify Moderator
front cap ?? Rear cap ??
Need more tech input for a good speculation on the problem.
laknox
Arizona
Posted: 09/20/23 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
OP is likely talking about the underside of the front overhang. Almost all of them sag, at least a little bit, after a few years; does't mean they're delaminating.
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
