RV.Net Open Roads Forum: Class A Motorhomes: RV Anti Freeze
 > RV Anti Freeze
rsinj
Princeton, NJ
Posted: 09/15/02 11:02am Link  |  Print  |  Notify Moderator
I definately agree that you don't want to put anti freeze in the fresh water tank
Be more specific. Why shouldn't you put anti-freeze in the fresh water tank? It is non-toxic. This is the reason you use RV/pink anti freeze to begin with - because you can put it in a fresh water system.
Although I don't agree with you, I am interested in your reasoning.
colo_crawdad
Colorado, United States
Posted: 09/15/02 12:04pm Link  |  Print  |  Notify Moderator
"I definately agree that you don't want to put anti freeze in the fresh water tank."
"Be more specific. Why shouldn't you put anti-freeze in the fresh water tank? It is non-toxic. This is the reason you use RV/pink anti freeze to begin with - because you can put it in a fresh water system. Although I don't agree with you, I am interested in your reasoning."
I'll take a shot at this one. It is next to impossible to "completely" drain most fresh water tanks. It is not difficult to get the lines clear.
Even though RV antifreeze is not harmul if ingested, it doesn't taste a good as fresh water. I can attest to this since I put it in the fresh water tank the first year I winterized. It me took two full days of filling, flushing, draining, and re-filling the fresh water tank to get all of the residue out. Much simpler to simply by-pass the fresh water tank, fill the lines (which puts antifreeze in both the black and grey water tanks as well as in drains). Just use your current water pump to do this by turning a valve. If one doesn't have such valve it is worth the money to get one installed. If the hot water heater isn't bypassed it seems to just take about six extra gallons of antifreeze. Again, it is cost effective to get a bypass installed (or do it yourself).
'94 31 ft. Damon Frontier Flyer
with a 97 Saturn SC2 pushing it
rsinj
Princeton, NJ
Posted: 09/15/02 12:56pm Link  |  Print  |  Notify Moderator
Thanks colo. Wouldn't know how it effects the taste - we never drink the water.
fmon
Eclipse, VA
Posted: 09/16/02 08:30am Link  |  Print  |  Notify Moderator
I agree with Bob about the air. After using the air first for a couple of years, I then scratched my head and wondered, why do this – I’m going to follow the air procedure with liquid anyway?
The check valve used to fill the hot water tank will have water in it after draining the tank. Pumping a little antifreeze through it should be considered, then use the hot water tank bypass.
My system also has 4 ft of piping between the fresh water tank and my antifreeze bypass valve, which is just prior to the intake of the water pump. Thus I need a small amount of antifreeze in the tank to pump through that pipe which if not attended to, may freeze. I get this small amount by opening the valve, which is used to fill the tank, then pump from the bottle a few oz of fluid into the tank. Then closing the tank fill valve and antifreeze bypass valve, I pump that little amount through the pipe and into the system. Next I open the antifreeze bypass valve and a hot water valve and pump a little through the intake valve on the hot water tank mentioned above. Now bypass the hot water tank and proceed with the rest.
Frank
Frank & Nancy
Allegro w/big tanks
01' Satrun LW200 TOAD
Roadmaster Sterling
Brake Buddy w/Breakaway and Remote
N7TOF
p
Posted: 09/15/02 08:18pm Link  |  Print  |  Notify Moderator
I have never run the "pink" antifreeze in the fresh lines for exactly the reasons given--it takes forever to get the taste out ( I learned from friends mistakes) I use air to blow the lines,open drain on hot water tank, turn bypass valves on water heater. And make sure you operate to toilet to drain water there. I then remove the water filter element and discard, leave all valves open, take sink drains apart (good time to clean out the crud) and then reinstall traps. Lastly put about a cup of RV antifreeze in traps and about 3 cupt in shower drain. Thus providing a seal against ordors. And about a cup in the toilet to keep the valve from sticking. Don"t forget the "low point drains" open them. Using this procedure for 10 years and no problems. Good luck.
Jim & Sandra Mattes
N7TOF & N7ZHK
Deen
Vancouver, WA
Posted: 09/15/02 09:11pm Link  |  Print  |  Notify Moderator
If you don't put the anti freeze into the lines you will need to put bleach water into everything when you de-winterize as the mold and crud has a chance to grow. If you think blowing the lines out removes ALL the water, it won't and there will be enough moisture to let the mold, slime, etc grow very well inside the tank and pipes.
Tara361
Denver, CO 80233
Posted: 09/16/02 12:00am Link  |  Print  |  Notify Moderator
Hi Zincat
I do mine like a lot of the others but I don't blow it out with air first. I don't see what the reason is for the air. When you run the anti-freeze through all the faucets and toilet (after the water heater is drained and bypassed, fresh water tank drained, low points drained etc,) all the lines will be full of antifreeze so why blow it out first?? Incidently I don't put the anti freeze in the fresh water tank, I use the T off of the water pump.
I'd certainly like to know why the air first, maybe I'm missing something I should be doing
Bob
Catty and Bob
2001 Flair 25F
Proud to be an American
Hutch1358
Tewksbury, MA
Posted: 09/15/02 06:07pm Link  |  Print  |  Notify Moderator
In the past I have put anti-freeze in the water tank. It takes forever to get the taste and smell out. You wouldn't want to use it for cooking or bathing either.
Celia Lee, Hutch & Dixie our Choc. Lab
Good Sam & KOA
2007 Keystone Everest 344J, Quad Slides
2005 Ford F-350,Crew Cab, SWB, 6.0 Diesel, Reese 16K Slide Hitch
benwd
summer lake, or, us
Posted: 09/15/02 06:25pm Link  |  Print  |  Notify Moderator
There's no need to put antifreeze in the fresh water tank as when it is drained the small amount left behind can freeze without hurting anything [plenty of room for expansion].
Note: Due to invalid formatting, all formatting has been ignored.
ffitzg
Middleton MA
Posted: 09/16/02 08:51am Link  |  Print  |  Notify Moderator
That was a good a procedure description as there can be. My MH uses about 2-1/2 gals. I don't use any air. My only additional advice is to disconnect the water line from the ice maker if you have one and let it cycle two or three times.
Frank (and Pat) FitzGerald Just North (15 mi.) of Boston RexAir and Saturn Toad No Kids or Pets ['ceptin' Pat] on board
 > RV Anti Freeze
