RV.Net Open Roads Forum: Fifth-Wheels: Superglide 16K Pullrite
 > Superglide 16K Pullrite
CYLABS
Posted: 09/24/02 04:25pm Link  |  Print  |  Notify Moderator
16K SUPERGLIDE video,,arrived today& it is a done
deal!!! Will save money in long run so it is worth the big BUCKS!!!
The input from every one really HELPED a lot
Thanks,
CLABS
wittmeba
Virginia
Posted: 09/24/02 09:27pm Link  |  Print  |  Notify Moderator
MNArt,
Thanks for the explanation...I understand what you are saying.
mckenziedt
WINNIPEG, MB.,Canada
Posted: 09/25/02 10:51pm Link  |  Print  |  Notify Moderator
MN Art has it right.You can come back at up to about 15o angle and be OK, but no sharper angle than that. But if you're not fairly well centered on the pin, things don't want to go together. I think that was the cause of my little experience chronicled in my above post. One of the distractions referred to was the fact that I couldn't see directly back out the rear window when I was backing into the pin, due to people in the way in the back seat. While I was not at an angle, I was off to the left a couple of inches. I felt resistance before the latch had fully engaged and stopped then. In normal circumstances the resistance wouldn't have been felt until I was all the way into the receiver,at which time the latch would have triggered. All I had needed to do was look at the locking lever and I could have seen it wasn't engaged, but I didn't,since I meant to look when I came back. Meant to and should have can have two different results.
*This Message was edited on 25-Sep-02 10:56 PM by mckenziedt*
Don M
2002 Chev 2500HD 4X4 LT CrewCab,Dk Green,DMax/Alison,Line-X short-box, 2003 33'Newmar-Kountry Star,PullRite16K SuperGlide,Prodogy,Honda EU2000i,
CYLABS
Posted: 09/29/02 05:16pm Link  |  Print  |  Notify Moderator
We priced the Superglide,,,$1,820.00....
Then they said four hours to install....
At $75.00 per hour....
Does this sound funny to anyone else??
2003HD/Alison/cc/SB
choc.lab
yellow lab
