RV.Net Open Roads Forum: Tech Issues: valve-extensions
 > valve-extensions
richmondmj
St. Cloud, Fl , USA
Posted: 11/05/01 11:59am Link  |  Print  |  Notify Moderator
I've had extenders on my Lazy Daze 26.5MB that I got from Jae Enterprises for almost a year and they have never leaked. Some people don't tighten them up propely or check them periodically to make sure they are tight and aren't rubbing the side of the holes in the liners. If they do that for long they can get holes in them and fail. You can get ones that don't tranfer the actuator valve to the extender which eliminate that problem. They cost a bit more for the zero air pressure type, but if you are concerned you could go that route. CW sells that type and are called airless extenders.
No mfg of dually trucks puts extenders on that I'm aware of. They are strictly an aftermarket item. All dual rear wheel vehicles have the same stem configuration. The outer wheel is attached backward, so the stem will point toward the center of the vehicle. They don't make different rims for the inner and outer, if they did you'd need 2 spare tires. They do make 135 degree solid extenders for the outer dual. There is also a company in Ca. (The Tire Man) that has solid brass stems for the rear duals to replace the standard ones. They are like the stems on large trucks. If you use them, you may want to paint them black or chrome look or get them chromed first before installing them since the brass will tarnish and look bad against a stainless steel liner or cover.
shooter
Goldsboro, NC, USA
Posted: 11/05/01 03:17pm Link  |  Print  |  Notify Moderator
Used long rubber extenders on two different MH's
for 89,000 miles. First failure occured last month in Pigeon Forge as I pulled into the
campground. Luck of the Irish, I guess. Due to
age and infirmity I can't check air or refill without them. I do use metal valve stems; I consider them a must.
Shooter
2002 Gulfstream Conquest towing 2003 Saturn LW 200
PCMentor
29 Palms, CA, USA
Posted: 10/22/02 12:41am Link  |  Print  |  Notify Moderator
I have a hard time finding those longer valve stems that are metal. Can you tell me of a place to order them from? Thanks, Pete
Pete and Dolores
Our 21' 1985 Dolphin - Thanks for your reply
MELM
GA
Posted: 10/24/02 09:00am Link  |  Print  |  Notify Moderator
There was a thread on this a while back, and a point made in it was that if you use extenders or the braided hoses, you need to have metal valve stems on the wheels. The rubber ones can simply break from the flexing from the additional load.
Mel & Mary Ann; Mo'Be (More Behave...) and Bella
"If you have an RV, you don't need another hobby." Comment from a friend...
90 Champion LaSalle MH 29 ft P30 (89 Chassis)
Visit The Official Blog of the Open Road
Sea Dog
Ontario Can.
Posted: 10/24/02 06:02pm Link  |  Print  |  Notify Moderator
I carry one of those nut drivers that is like a socket on a screw driver handle.
Works great to remove and replace the acorn type caps.
Life is short,Death is long,
Take a vacation.
mlg 626
Il
Posted: 10/25/02 07:42pm Link  |  Print  |  Notify Moderator
Do you realy think Ford gives a crap about your disincentive to proper maintenance? Like you said "thanks for your experience" well that's my experience, Didn't you write to this forum for an experienced reply??
Pirate
Northeast Tennessee
Posted: 10/25/02 10:11pm Link  |  Print  |  Notify Moderator
Huh???
onecb
Salt Lake City Utah
Posted: 10/23/02 08:39pm Link  |  Print  |  Notify Moderator
I have been using the extenders with the stainless braid around them for 15 years and have not lost air even once. Four MHs and six sets of tires. Just make sure they are tight and don't rub. It takes longer to get capps off than it does to check the pressure.
Alvin
LAJERHOFF
MISSION VIEJO, CA. USA
Posted: 10/23/02 09:06pm Link  |  Print  |  Notify Moderator
I installed the steel braided flexable extenders that are at Camping World and have had them on for approx 8 years and have had no problems, really makes it easy to sheck the tires.
Jerry/Laura and Shooter (Jack Russell)
1994 36ft Monaco Dynasty
1994 Jeep Cherokee">
BPOE #2444
FMCA F314862
aardvark
Kalispell MT
Posted: 10/26/02 05:21pm Link  |  Print  |  Notify Moderator
Had same problem with outside duals.
My easy fix? I just had the tire shop pull the stems and turn them around so they face out!!!
Now I am happily checking tires every morning before pulling out.
Live not for the day, but in it!
Matt 6:34
 > valve-extensions
