RV.Net Open Roads Forum: Class C Motorhomes: Ford Motorhome Escallation Path
 > Ford Motorhome Escallation Path
HiTech
Posted: 01/15/06 07:38am Link  |  Print  |  Notify Moderator
I have been in discussion with Ford and GM on a good contact for chassis issues for our members. So we do not swamp this individual with calls and loose this direct line, I'd ask everyone to first call the:
Ford Motorhome Hotline
800-444-3311
If they cannot help you with your question or issue, then we can use the contact Ford came through with:
Chris Keady
Commercial Vehicle Operations
Modified Vehicle Specialist
ckeady@ford.com
313-845-0452
I need to give him a call but sharing his contact info was approved by Ford VP's.
Class C Moderator
* This post was edited 01/15/06 10:38am by HiTech *
kaagee
Burlington Ontario
Posted: 01/15/06 07:57am Link  |  Print  |  Notify Moderator
HiTech...GREAT idea.. Thank you very much.
Ken
HiTech
Posted: 01/15/06 07:59am Link  |  Print  |  Notify Moderator
If you are at the Tampa RV show this week, I think Chris is there instead of in the office in Dearborn.
Westronics
Redmond, WA
Posted: 01/15/06 09:23am Link  |  Print  |  Notify Moderator
Can you add this to the FAQ or even make it its own sticky post at the top of the page?
2002 Jayco Greyhawk 24SS, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV Tires
HiTech
Posted: 01/15/06 10:37am Link  |  Print  |  Notify Moderator
Done.
* This post was edited 01/18/06 12:07pm by HiTech *
