casper6871
Smithville Texas
anyone know where to get a kit to connect the roadtrip gas grill to the motor home. the grill comes with a regulator that has that special fitting on it, however the quick connect to the rv is already stepped down so its double regulated and not enough presure to operate.
2009 Berkshire 390 Bunk House
2000 Dutchstar DP3859 *SOLD*
BIG trailer with expensive toys inside
Headed to a Dragstrip near you ">
BarneyS
S.E. Lower Michigan
Check out this thread for some ideas.
You may need this kit to get you going.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Gene&Ginny
North Kingstown, RI
I just posted this picture in the thread BarneyS linked to above. I made this up to connect my Roadtrip to my low pressure quick connect.
![[image]](http://i53.tinypic.com/nv7ejd.jpg)
The regulator part does unscrew from the tubing.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
RoyB
King George, VA
I just never really saw the need to do this mod.... I always have the 1lb cans around and they are available everywhere... I use them on my Mr Buddy heaters as well...
I guess one day I will run out way-back-in-the-woods and wish I was connected to the big tank haha...
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
ISM500
Manitoba
Gene&Ginny wrote: I just posted this picture in the thread BarneyS linked to above. I made this up to connect my Roadtrip to my low pressure quick connect. ...snip...
Thanks. I needed that.
casper6871
Smithville Texas
anyone figured a way yet to get the roadtrip hooked to the big tank without double regulating it?
BarneyS
S.E. Lower Michigan
casper6871 wrote: anyone figured a way yet to get the roadtrip hooked to the big tank without double regulating it?
That is what this year old thread is about. You have received some good suggestions on ways to do it. Have you tried any of them in the past year since you originally posted this thread? ![scratchead [emoticon]](http://www.rv.net/sharedcontent/cfb/images/scratchead.gif)
Barney
fyrflie
Martinez, CA. USA
I put a Tee with a Brass valve on my MH propane tank before the regulator. On the Tee after the Shut off valve is a quick connect that I use to connect a 20' hose that can be used to run the Roadtrip Grill or lantern or anything else I need.
timc1207
I just bought a 20 pound bottle from home depot and a hose kit, that's enough to last me for a lot of BBQs!
2015 Jayco 33RLDS - 2015 Dodge 2500 Laramie 6.7L Cummins diesel, Mygig Lock Pick, tonneau cover, Ranch Hand grill guard.
casper6871
Smithville Texas
BarneyS wrote: casper6871 wrote: anyone figured a way yet to get the roadtrip hooked to the big tank without double regulating it?
Barney
No Barney, unfortunately the suggestions didn't help, yes this thread is a year old and I'm still looking to get my road trip hooked to the low pressure line on the motor home.
Coleman uses a weird connector to the unit itself and that fitting is fused to the reg. so when connected to the low pressure side it's double regulated and has no flame. I know exactly what I need, just don't know if anyone makes it.
