RV.Net Open Roads Forum: Portable electric heater that doesn't burn out?
 > Portable electric heater that doesn't burn out?
kitch251
Aiken, SC
Posted: 04/08/12 08:11am Link  |  Print  |  Notify Moderator
Do you have a surge protector on you Coach?
Jim
hottubkid
SCHAUMBURG,IL
Posted: 04/08/12 08:19am Link  |  Print  |  Notify Moderator
X2
Teacher's Pet wrote:
We've been using a Pelonis Ceramic Disc Heater for over 20 years without a problem. 1st in our home in a "cold" bathroom and now for 6 years in our motorhome as we fulltime. I saw one the other day in a hardware store for about $75.
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
deandec
Northern CA
Posted: 04/08/12 10:08am Link  |  Print  |  Notify Moderator
We have two drugstore purchased electric heaters. We have lost power while they are running. Sometimes because one of them is running.
No problems afterwards with the heaters.
You might be having a surge problem upon restoring power to the coach.
Dean
95 CC Magna, Jeep GC
wny_pat
Western NYS
Posted: 04/08/12 11:42am Link  |  Print  |  Notify Moderator
hottubkid wrote:
X2
X - 3! Well over 20 years now. And use it at home and it has gone through lots of black outs. Don't know what to tell you. If it were me, I'd tear into it and see what is burned up and preventing it from starting up again.
Have you tried to unplug it for a while and then plug it back in?
“All journeys have secret destinations of which the traveler is unaware.”
Smittyy
Midwest
Posted: 04/08/12 12:01pm Link  |  Print  |  Notify Moderator
We purchased the Dyson Hot this winter and have been very happy with it , small footprint and great output.
wa_desert_rat
Central Washington State
Posted: 04/08/12 12:03pm Link  |  Print  |  Notify Moderator
Buy a "Kill-a-Watt" (under $30 at Lowe's or Home Depot) and check your voltages, power factor (on generator). You can also see frequency. No RVer should be without one, anyway.
Craig
Bumpyroad
Virginia
Posted: 04/08/12 12:05pm Link  |  Print  |  Notify Moderator
other than a power surge that doesn't make sense. no different from turning it off and back on manually. but get a $17 ceramic cube and save your money.
bumpy
2ndhom
Eugene, Oregon
Posted: 04/08/12 01:52pm Link  |  Print  |  Notify Moderator
Sounds as if your surge surpresser is not working. I'm not sure if you have one built into your inverter or not. Better search out that situation before buying another heater.
old guy
Oregon (pronounced Or e gun)
Posted: 04/08/12 01:53pm Link  |  Print  |  Notify Moderator
may be it's not the heater may be it's you. Do you have a surge protector? might be a cheaper investment for you
garry1p
Oklahoma
Posted: 04/08/12 03:58pm Link  |  Print  |  Notify Moderator
Short of a lighting strike a heater with out digital controls should not fail because the power is interrupted.
The only thing I can think of is you have a 50 amp coach and somehow the outlet you are using is getting hit with 250VAC temporarily because it is miss wired at the breaker box and I'm not sure how even that would happen.
If you have had the failure at different outlets then??
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
