RV.Net Open Roads Forum: Fifth-Wheels: WHY HAVE A BATTERY
 > WHY HAVE A BATTERY
laknox
Arizona
Posted: 06/25/12 12:42pm Link  |  Print  |  Notify Moderator
Nalphins@charter.net wrote:
My battery only will open slide but not turn on coffee pot...what gives??
Unless you have a 12v coffee pot, you need to be plugged in to shore power to make coffee...or use an old-fashioned percolator on the stove. I guess you could run 110v off an inverter, but you'll kill your battery PDQ.
Lyle
1936 John Deere Model A
International Flying Farmers 58 Year Member
2112
Posted: 06/26/12 05:57am Link  |  Print  |  Notify Moderator
Mile High wrote:
2112 wrote:
Fridge will only work when traveling while the engine is running. Stop for an hour on a hot summer day and your ice cream will melt. Ask me how I know.
OK, how come your ice cream melted? Did your propane changeover fail to start or are you running one of the new residential fridges on an inverter and the batteries dropped too fast?
As said, the controller still requires 12V to operate. The propane is useless without the controller to control it. Without the battery or 12V provided by the TV, no fridge. I used my last TT for about two years without a battery. It went bad and I realized I really didn't need it, no slides. The down side was the fridge didn't work when you turned off the TV.
2013 KZ Durango 2857
Mile High
CO
Posted: 06/26/12 03:06pm Link  |  Print  |  Notify Moderator
Ahh - the rest of the story. You didn't mention you were running the trailer without a battery. Makes sense now.
2013 Winnebago Itasca Meridian 42E
1997 Jeep Wrangler TJ Sahara Towed
mena661
Posted: 06/26/12 04:40pm Link  |  Print  |  Notify Moderator
You need it for the breakaway switch for sure. Since you have a new 5th wheel, your converter more than likely doesn't require a battery in place (don't know of any new converters that need one). Even if all I did was go to full hookup campgrounds, I'd still have a couple of group 27's for the occasional power outage so I could continue to run the heater, fridge and other 12V stuff.
Trojan L16 6V's 740 Amp-hours
N3YMY
Brunswick, MD
Posted: 06/28/12 03:55pm Link  |  Print  |  Notify Moderator
lovemountains wrote:
The propane refrigerator with electronic controls MUST have either battery power or 110 in order to work.
Our new dometic requires 12VDC on propane or AC.
Pull the DC fuse to the reefer and see for yourself on AC ...
Michigan
Posted: 06/28/12 04:08pm Link  |  Print  |  Notify Moderator
Its true I disconnected the battery and frig went down, thank goodness I was looking for problems...
Carlos & Ranae
Orlando, FL
Posted: 07/06/12 08:19pm Link  |  Print  |  Notify Moderator
The Big Country comes equipped with a battery disconnect. Even after two months, the battery should be ok, assuming you have a deep cycle marine battery.
Carlos & Ranae
2017 Seismic 4212
2012 Dodge Ram, 3500 Laramie Longhorn
4X4, DWR, Pullrite 18KSuperslide Hitch
2006 Yamaha Midnight Silverado, 1700 CC
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
