RV.Net Open Roads Forum: Fifth-Wheels: burner igniter switch
 > burner igniter switch
maggie61
Renfrew, Ontario
Posted: 07/18/12 07:12pm Link  |  Print  |  Notify Moderator
The burner on our stove in our RV can be light be turning a switch along the front of the stove, until it ignites, or you can light the burner with a match or lighter. However, the last time we were camping, it wouldn't ignite when turning the knob to the right two or three times. We have used it before and it worked the last time we were out camping. It did light with a lighter when we couldn't get it lite with the igniter switch.
Passin Thru
N VA
Posted: 07/18/12 07:34pm Link  |  Print  |  Notify Moderator
Moisture maybe or low gas pressure or gas may not have reached the burner until you tried to light it.
rhagfo
Portland, OR
Posted: 07/18/12 07:36pm Link  |  Print  |  Notify Moderator
Yea the igniter knob. [emoticon]
Our old 86 King of the Road had a pilot light, that was sweet.
The igniter creates a spark at a location central to the three burners. Each burner has a tube that directs gas to the spark source. Either it is not creating a spark, or the tubes have been dislodged from the burner head.
I would guess no spark, check by lifting the top of the stove an look for it at the center of the three burner locations. You may need a new spark unit.
Russ & Paula
The Beagles Hedwig (Passed), Precious, and Belle.
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,Bilstein 5100's, 296,000 miles.
2005 Copper Canyon 293 FWSLS, 32' GCVW 19,500#
Jeremy626
Chicago Burbs
Posted: 07/18/12 08:52pm Link  |  Print  |  Notify Moderator
when you click the sparker, are you seeing the spark? I had this problem once and I lifted up the lid on the stove to expose the burner tubes and stuff and one of the sparker wires had come disconnected from that burner. plugged it back in and was back in business.
Jeremy
Rig: 2011 Palomino Stampede S-21RGS 3 Bed Hybrid
TV: 2007 Chevy Tahoe LTZ 5.3L V8, 3.73
Equal-i-zer, Prodigy BC
Moki
WI USA
Posted: 07/19/12 08:58am Link  |  Print  |  Notify Moderator
Lift the stove top and find where the sparker wires are connected. Pull these connections apart, wiggle them, clean the connections good, and then reconnect. Just a tiny bit of corrosion will prevent them from sparking at the burner. High humidity, like we have been having, is a real culprit. Had this all the time with the stove when I had a truck camper.
2013 Ford 250 6.2 gas Ext cab 8' bed SRW
2011 Cougar 276RLS
PullRite 18K OEM Hitch
EU2000i
WB9MKZ
Mile High
CO
Posted: 07/19/12 10:58am Link  |  Print  |  Notify Moderator
That thing is a little fickle for me. 50% chance it will light when I go there. I never looked into why, I just keep a lighter close
2013 Winnebago Itasca Meridian 42E
1997 Jeep Wrangler TJ Sahara Towed
laknox
Arizona
Posted: 07/19/12 01:46pm Link  |  Print  |  Notify Moderator
x3 on the igniter wires coming loose, as first suspicion. Keep matches/lighter handy, though. :-)
Lyle
1936 John Deere Model A
International Flying Farmers 58 Year Member
DennisG9
United States
Posted: 07/20/12 07:05am Link  |  Print  |  Notify Moderator
Might check the sides of your burners to. Sometimes a pot will boil over and clog the small gas openings in the side of the burner that feed the tubes to your central ignighter.
93Cobra2771
East Tennessee
Posted: 07/20/12 09:00am Link  |  Print  |  Notify Moderator
I adapted mine over to an electric sparker like most newer/bigger grills have. That puppy sparks like no tomorrow. Multiple discharges takes all the guesswork out of "is is sparking or not".
Theres a thread in the DIY forum somewhere that shows how to do it.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
wittmeba
Virginia
Posted: 07/20/12 10:53am Link  |  Print  |  Notify Moderator
If the sparker is not producing a spark, look for an "AA" battery in the lighter wiring.
I just replaced a Piezo lighter on a BBQ grill. The button had the battery and the unit was sealed with 4 leads - 1 for each burner.
Be careful - they can produce a slight shock. Dont ask how I know [emoticon]
NRA Member & supporter of the 2nd amendment - over 5,000,000 strong
Firefox® 33
Log home images - Updated 05/19/2013
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
