RV.Net Open Roads Forum: Class A Motorhomes: A/C humming
 > A/C humming
bluebarry1964b
Homestead, Florida
Posted: 08/11/12 04:07am Link  |  Quote  |  Print  |  Notify Moderator
I have a Duo-Therm (Domestic) rooftop airconditioner. Tonight it has started to make a deep humming sound. It is still blowing cold air just fine, but the weird thing is that when I try to shut off the a/c unit at the thermostat, the unit stops blowing air, but doesn't shut off. I still hear this deep humming sound as if something is still turned on in the a/c unit. I'm having to shut the breaker off at the breaker box in order to get the a/c unit to shut off completely & stop the humming sound.
Has anyone else experienced this, and if so, what is it, and what is the solution? Thanks.
Ranger Smith
Wherever the rig is parked
Posted: 08/11/12 05:26am Link  |  Quote  |  Print  |  Notify Moderator
It is your control board on the AC that is bad. Mine did the same thing. Fan is shutting off but compressor is staying on.
Where We Are Now
Amateur Radio Operator KK9W ARRL VE Icom 7300 Kenwood TS-990
Steve and Joy
2013 Winnebago Journey 34B
Cooper ... The Aussie-Doodle, Yogi...The Yorkie, Cookie ... The Chihuahua
dougrainer
Carrolton, Texas
Posted: 08/11/12 06:28am Link  |  Quote  |  Print  |  Notify Moderator
You need a 5 button Dometic CCC AC control board. The Compresor relay on the board is stuck and the relay is NOT a seperate part. Doug
barnaclebill
Atlanta Michigan or towards the sun
Posted: 08/11/12 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Doug, mine does the same thing, it is a penguin with heat pump, but if I shut off at the breaker and turn it back on after 10-15 minutes it runs fine, cycles on and off but then will do the same thing again maybe 1-2-3 days later. Any thoughts? Thanks, Bill
2003 41' Newmar Mountain Aire
400 Cummins
Jeep Liberty
Blue Ox Brake Buddy
dougrainer
Carrolton, Texas
Posted: 08/11/12 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Same relay and problem. Doug
tropical36
Southwest Florida_USA
Posted: 08/11/12 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Had some issues with our dometic. Story short, after replacing the burnt out fan motor, it still wouldn't run, although the compressor always would. Disconnected the connector from the inside and checked it for burnt contacts or whatever and pulled the 3amp pcb fuse which was OK. reinstalled both and the fan took off????
Have no clue as to why except that it might have reset the control board.
About a year or two ago the old fan motor froze up. Disassembly and some grease on the bearing surfaces cured that problem until now. Did this most recent repair in this campground as I had the new motor on board and so far so good.
As a side note, the fan motor doesn't use a start capacitor and shares the run capacitor with the compressor, so one might want to consider these items in troubleshooting also.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E__Spartan MM_06 C9 Clatterpillar_Allison 3000
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
barnaclebill
Posted: 08/11/12 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your quick reply, Bill
bluebarry1964b
Homestead, Florida
Posted: 08/11/12 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Is it the circuit board on the wall thermostat that's no good, or the circuit board in the a/c unit itself?
dougrainer
Carrolton, Texas
Posted: 08/11/12 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
The AC circuit board, NOT the wall tstat. Doug
tropical36
Posted: 08/11/12 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing the a/c itself if your compressor is running and what I was referring to with mine.
 > A/C humming
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
